Shifter level
Tome Rodos
Hello to everyone this was my problem yesterday what i sorted today the Yamaha shifter what's have the bolt on to change the gear with the axle is not good metal alloy but soft i tried to install quick Sifter and my problem was what stops moving free and I try to loosen and crack on 5 peace so i bye this and installed have any one else tried this if will be ok?
In case you are not aware, the threads on the lower end of the rod, and the locking nut, are both reverse threaded.  I destroyed the OEM rod and nut when I was trying to replace it with the quick shifter.  Complete ignorance on my part and not any fault of the material used.
You’ve come this far. Try it and let us know how it goes!
