Braided steel cables. Kit from stoltec. Kept the abs pump.
Per advice, I also changed out the master cylinder for a smaller. 11mm from a wr250r.
The problem is that the brakes were siezing, it happened twice at speed. I think the reservoir wasn't big enough. I went back to the stock master cylinder. I did try swapping calipers and rebleeding everything just to be sure but that seems to be the issue.
Did I do it wrong? I thought this was a setup others used with success. Possibly because I kept the abs that the MC was under sized?
Ethos
Single disc conversion.
Edited by EthosLink to comment
7 answers to this question
Register a new accountSign in
