Power cut problem
Gezgin Endurocu
After falling on the ride off-road ,I have a gas cutting problem in the engine, no sensor fails the engine. There is too much black dust in the exhaust. Why do you think it may be caused? Could it be related to loose socket or spark plugs? And olur lambda sensor Same as tracer or mt07 ? Code is 2CR8592A2000 maybe ı need ....
Check your side stand switch. Maybe it got damaged slightly when you fell?
6 minutes ago, Redbikejohn said:
Yan sehpa anahtarınızı kontrol edin. Belki düştüğünüzde biraz hasar görmüştür?
I dont think so bike is working , is it cause powercut ?
If it was bent slightly in the crash it could be just operating the switch momentarily and cutting power on and off. Simple to check, just bypass it.
